[mapguide-trac] #1631: Map Definition Editor Defects
MapGuide Open Source trac_mapguide at osgeo.org
Wed Mar 16 06:39:34 EDT 2011
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  medium   |   Milestone:  Maestro-3.0
  Component:  Maestro  |     Version:
   Severity:  major    |    Keywords:
External_id:           |
 The following defects were observed with the Map Definition Editor in
 Maestro 3.0 beta 1:
  * Deleting layers does not clear the layer editor
  * Deleting folders does not clear the folder editor
  * Dropping a Layer Definition into a Base Layer Group will not add it to
 the group, but rather creates a new base layer group instead.
  * Drag/drop reordering of layers in a base layer group does nothing.
  * It is possible for System.NullReferenceException to occur when adding
 the first layer to a Map Definition due to the fact that it naively
 assumes that obtaining the extents for the layer will always succeed.
  * Manual Scale List editor textbox does not allow the return keypress
  * Add a new validation rule: A map definition with 1 or more base layer
 groups, must have 1 or more finite scale ranges defined.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1631>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
