[mapguide-trac] #1633: Wrong tooltip showed
trac_mapguide at osgeo.org
Wed Mar 16 20:10:40 EDT 2011
Reporter: mphaneuf | Owner:
Type: defect | Status: new
Priority: low | Milestone:
Component: General | Version: 2.1.0
Severity: minor | Keywords: tooltip, views,
External_id: |
Comment(by zspitzer):
Is this with the AJAX Viewer?
Do you mean your are authoring off a view with databases joins? If so the
view must present a Primary Key, just like a normal table, otherwise it
does cause problems.
I know this can be done in Oracle (i.e create a primary key on a view) but
you
will need to investigate how to do this in Sql Server
In the future, please post to the mailing list before filing an issue in
trac
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1633#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
