[mapguide-trac] #1635: Fusion editor defects
MapGuide Open Source trac_mapguide at osgeo.org
Thu Mar 17 06:29:29 EDT 2011
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-3.0
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
Changes (by jng):
 * cc: zspitzer (added)
Old description:
> This ticket is an umbrella ticket for the fusion editor
>  * Delete button in widget configuration dialog does not remove the
> underlying widget from the widget set
New description:
  * The the map editor needs to be re-designed as it is currently hardcoded
 for certain map providers. Most particular, it will only allow 1 MapGuide
 map provider (and a choice of Bing/Google/Yahoo providers). Thus the
 editor prevents the ability to have a MapGroup with multiple MapGuide maps
 in it (eg. A dynamic map definition and a tiled map definition together)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1635#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
