[mapguide-trac] #1631: Map Definition Editor Defects and Loose
Ends
trac_mapguide at osgeo.org
Mon Mar 21 07:58:43 EDT 2011
#1631: Map Definition Editor Defects and Loose Ends
Reporter: jng | Owner: jng
Type: defect | Status: new
Priority: medium | Milestone: Maestro-3.0
Component: Maestro | Version:
Severity: major | Keywords:
External_id: |
Description changed by jng:
Old description:
> The following defects were observed with the Map Definition Editor in
> Maestro 3.0 beta 1:
> * ~~Deleting layers does not clear the layer editor~~
> * ~~Deleting folders does not clear the folder editor~~
> * ~~Dropping a Layer Definition into a Base Layer Group will not add it
> to the group, but rather creates a new base layer group instead.~~
> * Drag/drop reordering of layers in a base layer group does nothing.
> * Drag/drop of an existing layer reference into a group ("Layers by
> Group" tab) does nothing.
> * ~~It is possible for System.NullReferenceException to occur when
> adding the first layer to a Map Definition due to the fact that it
> naively assumes that obtaining the extents for the layer will always
> succeed.~~
> * ~~Manual Scale List editor textbox does not allow the return
> keypress~~
> * ~~Add a new validation rule: A map definition with 1 or more base
> layer groups, must have 1 or more finite scale ranges defined.~~
> * ~~Editing the legend label incorrectly updates the layer display. This
> should be happening to the name component instead.~~
> * ~~Allow deletion of elements by Del keypress~~
New description:
Maestro 3.0 beta 1:
* ~~Drag/drop of an existing layer reference into a group ("Layers by
Group" tab) does nothing.~~
* ~~It is possible for System.NullReferenceException to occur when adding
the first layer to a Map Definition due to the fact that it naively
assumes that obtaining the extents for the layer will always succeed.~~
* ~~Manual Scale List editor textbox does not allow the return keypress~~
* ~~Add a new validation rule: A map definition with 1 or more base layer
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1631#comment:6>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
