[mapguide-trac] #1635: Fusion editor defects and loose ends
trac_mapguide at osgeo.org
Tue Mar 22 07:04:11 EDT 2011
Reporter: jng | Owner: jng
Type: defect | Status: new
Priority: low | Milestone: Maestro-3.0
Component: Maestro | Version:
Severity: trivial | Keywords:
External_id: |
Description changed by jng:
Old description:
> This ticket is an umbrella ticket for the fusion editor
> * Delete button in widget configuration dialog does not remove the
> underlying widget from the widget set
> * The the map editor needs to be re-designed as it is currently
> hardcoded for certain map providers. Most particular, it will only allow
> 1 MapGuide map provider (and a choice of Bing/Google/Yahoo providers).
> Thus the editor prevents the ability to have a MapGroup with multiple
> MapGuide maps in it (eg. A dynamic map definition and a tiled map
> definition together)
> * Add a new validation rule that checks if any Map Definitions conform
> to the Popular Visualisation Mercator coordinate system if it is part of
> a MapGroup that also has a Bing/Google/Yahoo provider in it.
New description:
* ~~Delete button in widget configuration dialog does not remove the
underlying widget from the widget set~~
* The the map editor needs to be re-designed as it is currently hardcoded
for certain map providers. Most particular, it will only allow 1 MapGuide
map provider (and a choice of Bing/Google/Yahoo providers). Thus the
editor prevents the ability to have a MapGroup with multiple MapGuide maps
in it (eg. A dynamic map definition and a tiled map definition together)
* ~~Add a new validation rule that checks if any Map Definitions conform
to the Popular Visualisation Mercator coordinate system if it is part of a
MapGroup that also has a Bing/Google/Yahoo provider in it.~~
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1635#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
