[mapguide-trac] #1640: Error editing schema for both new and
existing ODBC feature sources
trac_mapguide at osgeo.org
Thu Mar 24 08:20:26 EDT 2011
#1640: Error editing schema for both new and existing ODBC feature sources
Reporter: andrewd | Owner: jng
Type: defect | Status: new
Priority: high | Milestone:
Component: Maestro | Version: 2.1.0
Severity: blocker | Keywords:
External_id: |
Using Windows 7 x64 and having MGOS installed on Windows Server 2008 x64,
I can't create any ODBC feature sources without Maestro 3.0b2 throwing an
error (see attached screen cap). This happens using all of my DSNs, which
are located on the Windows 2008 x64 server, and is regardless of the type
of database (I get the error for Access databases and SQL databases). It
should be noted that these DSNs are 32bit.
This process worked fine in Maestro v2 (and even v1, actually).
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1640>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
