[mapguide-trac] #1648: Flush feature source command
trac_mapguide at osgeo.org
Thu Mar 31 23:34:23 EDT 2011
Reporter: jng | Owner: jng
Type: enhancement | Status: new
Priority: low | Milestone: Maestro-3.0
Component: Maestro | Version:
Severity: trivial | Keywords:
External_id: |
A common problem with a Feature Source that is in constant flux is that
schema information is cached for performance reasons resulting in the
schema information being out of date.
To flush this cached item normally you would need to call SaveResource on
the resource id of that feature source, which triggers invalidation of
that cached item.
To make this process dead simple, add a new "Flush Feature Source from
cache" command. The implementation of this command is also simple. We take
the resource content from a resource id and write it back to the same id.
This will trigger cache invalidation, ensuring the next schema walk
operation gives the current information.
This would not affect the any open editors of the same resource, as they
are operating off of a session-based copy.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1648>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
