[mapguide-trac] #1477: ODBC dataconnection (MS Access) problem
trac_mapguide at osgeo.org
Tue Nov 8 18:11:42 EST 2011
Reporter: andrewd | Owner: jng
Type: defect | Status: new
Priority: high | Milestone: Maestro-3.5
Component: Maestro | Version:
Severity: major | Keywords:
External_id: |
Comment(by trevorwekel):
Hi Jackie,
I have another example using an mdb using with an int16 column. When I
edit the schema to select X and Y columns, I get the following error
message
(559) MgFdoException.: An exception occurred in FDO component.
Error reading Feature Schemas from XML; class 'www-dot-w3-dot-
org/2001/XMLSchema:int16' for object property 'Fdo:Label.TextHorzAlign'
not found.
Do you have any suggestions? Maestro 4.0b1 also exhibits the same issue.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1477#comment:15>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
