[mapguide-trac] #1768: Implement RFC110 UI
MapGuide Open Source trac_mapguide at osgeo.org
Wed Nov 16 01:29:25 EST 2011
   Reporter:  yangte  |       Owner:  Ted Yang
       Type:  task    |      Status:  new
   Priority:  high    |   Milestone:
  Component:  Server  |     Version:
   Severity:  major   |    Keywords:
External_id:          |
Comment(by yangte):
 The ProfilingAPI_GUI_Part7 is mainly add error handling for performance
 report and fixed some UI defects:[[BR]]
 1. While profing the map, there will be errors if something wrong, so we
 must display the error message[[BR]]
 2. fix the problem that Apache+Jave will fail to open the "select setting"
 dialogue [[BR]]
 3. fix the problem that error message will not disapper when user click
 the "Recent Settings" to enter correct values[[BR]]
 4. fix the problem when export the profing data, the format of scale will
 be recognized as time[[BR]]
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1768#comment:8>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
