[mapguide-trac] #1867: Map Definition Editor: Support generating a
Yahoo/Bing/Google compatible finite scale list
trac_mapguide at osgeo.org
Mon Nov 28 06:06:46 EST 2011
#1867: Map Definition Editor: Support generating a Yahoo/Bing/Google compatible
finite scale list
Reporter: jng | Owner: jng
Type: enhancement | Status: new
Priority: low | Milestone:
Component: Maestro | Version:
Severity: trivial | Keywords:
External_id: |
The trunk build of Fusion finally support dynamic/tiled combinations. In
addition, this setup also works with commerical backdrops, but requires
the tiled layers use a compatible finite scale list.
Maestro should support generating such compatible scale lists
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1867>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
