[mapguide-trac] #1868: DataType inconsistency in LayerDefinition
trac_mapguide at osgeo.org
Mon Nov 28 08:41:43 EST 2011
Reporter: gBecker | Owner:
Type: task | Status: new
Priority: high | Milestone: Maestro-4.0
Component: General | Version: 2.1.0
Severity: major | Keywords:
External_id: |
Comment(by jng):
For all schemas in production (1.0.0 to 2.3.0) yes. This "defect" is set
in stone and cannot realistically be fixed.
Actually, the generated code returns double, but the interface that it
implements (ISymbol) properly returns string for both InsertionPointX and
InsertionPointY.
Since use of such types should always be done through its interfaces. The
behaviour is as intended. The only problem will be if you try to use an
FDO expression for InsertionPointY. Only then will the code actually need
to be updated. Otherwise nothing needs to be done. Frankly, I wouldn't try
to change anything here unless you have a need to use FDO expressions for
InsertionPointY
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1868#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
