[mapguide-trac] #1804: Skip building common.sln in build.bat
MapGuide Open Source trac_mapguide at osgeo.org
Sun Sep 11 21:37:20 EDT 2011
   Reporter:  jng           |       Owner:
       Type:  defect        |      Status:  new
   Priority:  low           |   Milestone:
  Component:  Build System  |     Version:
   Severity:  trivial       |    Keywords:
External_id:                |
 The build.bat and build64.bat files should skip building Common.sln
 The Server and WebTier solutions will build the shared component projects
 under MgDev/Common anyway, so building Common.sln is superfluous.
 But mainly this is to workaround #1803, which has rendered Common.sln un-
 buildable
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1804>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
