[mapguide-trac] #1817: filter problem with Maestro
trac_mapguide at osgeo.org
Sun Sep 25 03:02:43 EDT 2011
Reporter: captainst | Owner: jng
Type: defect | Status: closed
Priority: medium | Milestone: Maestro-4.0
Component: Maestro | Version: 2.2.0
Severity: trivial | Resolution: invalid
Keywords: Filter Layer Style | External_id:
Changes (by jng):
* status: new => closed
* resolution: => invalid
Comment:
The Layer Filter determines the whole set of features from this layer that
will be rendered out. The filter specified in each rule is what each
feature in this set must satisfy in order to be rendered out in the style
specified by that rule.
The filters in each layer rule do not actually do any filtering per se.
They just say what criteria a feature must satisfy in order to be rendered
out with that rule's specified style.
This is why it still takes 40 seconds because MapGuide still has to read
everything (because of no layer filter), but skips features that do not
satisfy any of the filters in your 3 line rules.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1817#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
