[mapguide-trac] #1819: Plot To DWF generates horizontal lines for small font sizes
MapGuide Open Source trac_mapguide at osgeo.org
Wed Sep 28 19:44:15 EDT 2011
   Reporter:  trevorwekel      |       Owner:  trevorwekel
       Type:  defect           |      Status:  new
   Priority:  low              |   Milestone:  2.2
  Component:  Mapping Service  |     Version:  2.2.0
   Severity:  minor            |    Keywords:  plot dwf
External_id:                   |
Comment(by waltweltonlair):
 This patch also affects rendering of geometry - geometry will rendered as
 is, and no points will be removed.
 In the case of generating a static EPlot the fix in the patch makes sense.
 But when rendering dynamic EMaps we want OptimizeGeometry to be true.
 So the patch needs to be adjusted to only set OptimizeGeometry to false
 when generating a static EPlot.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1819#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
