[mapguide-trac] #1982: QuickPlot command is broken in the AJAX viewer
trac_mapguide at osgeo.org
Thu Apr 12 07:44:00 EDT 2012
Reporter: jng | Owner:
Type: defect | Status: new
Priority: low | Milestone: 2.4
Component: AJAX Viewer | Version:
Severity: trivial | Keywords:
External_id: |
Invoke the quick plot command from the ajax viewer. Checking advanced
options or doing the plot straight away fails because it is interpreting
the frame hierarchy wrong.
Namely access to the map frame from a popup window is not:
opener.parent.parent.mapFrame
but rather:
opener.GetMapFrame()
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1982>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
