[mapguide-trac] #1984: AjaxViewer SetSelectionXML does not work
anymore on Mapguide 2.4
trac_mapguide at osgeo.org
Mon Apr 16 12:31:39 EDT 2012
#1984: AjaxViewer SetSelectionXML does not work anymore on Mapguide 2.4
Reporter: znarf1965 | Owner: jng
Type: defect | Status: new
Priority: high | Milestone: 2.4
Component: AJAX Viewer | Version:
Severity: blocker | Keywords: 2.4 Ajax viewer SetSelectionXML
External_id: |
Comment(by jng):
Ok, the problem is that we are getting a potentially dangerous
Request.Form value due to the selection XML.
Why did this not happen in MGOS 2.2? Because the MapGuide .net API was
still at .net Framework 2.0. For MGOS 2.4 and AIMS 2013, the MapGuide .net
API is now at .net Framework 4.0
This brings up another question. AIMS 2013 is obviously doing something
correct in this regard. The solution/workaround is to add this line to
under the {{{<system.web>}}} section of web.config in mapviewernet:
<httpRuntime requestValidationMode="2.0" />
This is where I'll need you to do some fact finding (as I do not have AIMS
2013 and you do). Does AIMS 2013 have this configuration setting for
mapviewernet? If so, I'll put this in as the official fix, otherwise we
need to find out the .net web application configuration differences
between MGOS 2.4 and AIMS 2013, something I'll need your help with.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1984#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
