[Mapguide-trac] [mapguide-trac] #2097: API documentation cleanup (was: Web API documentation missing tree and TOC)
MapGuide Open Source trac_mapguide at osgeo.org
Mon Aug 27 06:22:23 PDT 2012
   Reporter:  jng            |       Owner:  jng
       Type:  defect         |      Status:  new
   Priority:  low            |   Milestone:  2.4
  Component:  Documentation  |     Version:
   Severity:  trivial        |    Keywords:
External_id:                 |
Description changed by jng:
Old description:
> If you look at the generated Web API documentation for 2.4 and compare it
> to the "published" 2.0 version on mapguide.osgeo.org you can see there
> are some stark differences:
>  * The lack of a navigation tree
>  * The lack of a TOC
> The build process already warns about such issues, so something is
> definitely amiss here.
New description:
 The current Web API documentation source does not cleanly build with  the
 version of doxygen that we're using (1.8.0).
 In addition, the documentation itself is missing in some parts
  * Documentation of the WebApp classes (that are wrapped by the proxy
 classes in the the OSGeo.MapGuide.Web.dll assembly)
  * Some internal classes are being leaked out. Need to compare with the
 exposed classes of the .net assemblies to determine which classes need to
 be hidden.
 ~~If you look at the generated Web API documentation for 2.4 and compare
 it to the "published" 2.0 version on mapguide.osgeo.org you can see there
  * The lack of a TOC
 definitely amiss here.~~
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2097#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
