[Mapguide-trac] [mapguide-trac] #1633: Wrong tooltip showed
MapGuide Open Source trac_mapguide at osgeo.org
Thu Dec 20 21:42:04 PST 2012
 Reporter:  mphaneuf         |         Owner:
     Type:  defect           |        Status:  closed
 Priority:  low              |     Milestone:
Component:  General          |       Version:  2.1.0
 Severity:  minor            |    Resolution:  invalid
 Keywords:  tooltip, views,  |   External_id:
Changes (by jng):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 Views by default will probably not have an identity property, which will
 throw any sort of spatial query (selection/tooltip) into disarray.
 Use FDO schema overrides to apply identity properties:
  * http://themapguyde.blogspot.com.au/2010/08/using-fdo-schema-
 overrides.html
  * http://themapguyde.blogspot.com.au/2010/09/using-fdo-schema-overrides-
 redux.html
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1633#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
