[mapguide-trac] #1944: when the map's layers are from different
schemas, the features can't be selected
trac_mapguide at osgeo.org
Thu Feb 2 04:45:20 EST 2012
#1944: when the map's layers are from different schemas, the features can't be
selected
Reporter: christinebao | Owner: Christine Bao
Type: defect | Status: new
Priority: medium | Milestone:
Component: Web API | Version: 2.1.0
Severity: trivial | Keywords:
External_id: 1447700 |
Report from Autodesk QA:
QA ever tried on FDO Postgis and FDO SQLserver2005. The data store used as
test data contains multiple schemas.
steps:
1. In Studio, create a feature source, connecting FDO Postgis data
store.(server: acrdmapdb3; usr/pwd: postgres/postgres; datastore:
SAN_forAIMS_systemtesting)
2. create a layer named water for feature class: Default:water
3. create anotehr layer named zipcode for feature class:
Sanfrancisco:sfzipcodes
4. create a map, adding layer water and layer zipcode into it.
5. preview the map (no matter basic viewer or flexible web viewer)
6. try to select a feature on any layer
result:
the feature can't be selected/highlighted. In selection panel, it seems
that all the features on that layer are retrieved.
expectation:
the target feature is selected.
regression: N
workaround: N
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1944>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
