[mapguide-trac] #1948: Un-bufferable geometry in Sheboygan dataset
trac_mapguide at osgeo.org
Mon Feb 6 10:59:08 EST 2012
Reporter: jng | Owner:
Type: defect | Status: new
Priority: low | Milestone:
Component: General | Version: 2.2.0
Severity: trivial | Keywords:
External_id: |
Description changed by jng:
Old description:
> 1) Select the parcel in the attached screenshot (Autogenerated_SDF_ID =
> 8149)
> 2) Create a buffer from this selection with default settings
> Expect: A buffer to be created around the selected feature
> Got: The stock message for a C++ null pointer de-reference:
> Problem:\nThe application encountered a problem and could not finish the
> operation you just requested properly.\n\nSolution:\nIf it\'s the first
> time you met this problem, try again or restart the application /
> session; otherwise, describe the steps to reproduce this problem to the
> server administrator for suggestions.
> Modifying buffer.php to show the stack trace reveals it to be at:
> - MgGeometry_Buffer() line 14619 file MgApi_wrap.cpp
> Observed in the AJAX viewer (.net and PHP) in both MGOS 2.2 and trunk.
New description:
1. Select the parcel in the attached screenshot (Autogenerated_SDF_ID =
8149)
2. Create a buffer from this selection with default settings
time you met this problem, try again or restart the application / session;
otherwise, describe the steps to reproduce this problem to the server
Note that the un-bufferable feature in question is not the same feature
that had tripped up FDO in the past (http://trac.osgeo.org/fdo/ticket/382)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1948#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
