[mapguide-trac] #1909: LocalConfigure.exe writes bad temp path in
Platform.ini
trac_mapguide at osgeo.org
Tue Jan 3 21:52:28 EST 2012
#1909: LocalConfigure.exe writes bad temp path in Platform.ini
Reporter: jng | Owner: jng
Type: defect | Status: new
Priority: low | Milestone: Maestro-4.1
Component: Maestro | Version:
Severity: trivial | Keywords:
External_id: |
The LocalConfigure.exe writes TempPath into where Maestro is installed.
Given the install location is Program Files, which is a protected area in
Windows Vista and above, all operations involving temp/session resources
will fail.
LocalConfigure should be writing the same path used for all paths related
to the Resource Service
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1909>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
