[mapguide-trac] #1914: ResourceExists in MaestroAPI takes 1 second
to execute with LocalNative-Connection
trac_mapguide at osgeo.org
Fri Jan 13 07:27:55 EST 2012
#1914: ResourceExists in MaestroAPI takes 1 second to execute with LocalNative-
Connection
Reporter: gBecker | Owner: jng
Type: defect | Status: new
Priority: high | Milestone: Maestro-4.1
Component: Maestro | Version: 2.2.0
Severity: critical | Keywords:
External_id: |
When using LocalNative-Connection the methode ResourceExists of the
ResourceService takes more than 1 second to execute. Sometimes my WebPages
needs up to 10 seconds to load because of high usage of this methode. With
the old API the site loads very fast.
You can reproduce the problem with the SampleWeb of MaestroSDK_4.0.0.
Create a LocalNative-Connection and wrap tracing around the ResourceExists
methode in Default.aspx.cs:
Trace.Write("Begin");
if (conn.ResourceService.ResourceExists(mdfId))
Trace.Write("End");
Gunter
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1914>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
