[mapguide-trac] #1915: Labels failed to display for flexible web layout
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jan 16 04:13:28 EST 2012
   Reporter:  liuar    |       Owner:  liuar
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:
  Component:  General  |     Version:  2.1.0
   Severity:  trivial  |    Keywords:
External_id:           |
Comment(by liuar):
 This is caused by the cache in PhpLocalizer.cpp in php api.  It uses a map
 to cache localized texts and uses the local as the key. However, the local
 for flexible web layout and basic web layout are both "en".  That means if
 user loads basic web layout before the flexible weblayout, then the
 localized string for flexible web layout will never be cached and
 displyed, vice versa. [[BR]]
 [[BR]]
 To resolve the problem, I changes the key of the caching structure from
 local to LocalizationPath+Local, and both localized strings for basic web
 layout and flexible web layout will be cached.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1915#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
