[mapguide-trac] #1925: Maestro - Oracle Test Validation Invalidates
Resource
trac_mapguide at osgeo.org
Thu Jan 19 07:30:08 EST 2012
#1925: Maestro - Oracle Test Validation Invalidates Resource
Reporter: crispinatime | Owner: jng
Type: defect | Status: new
Priority: low | Milestone: Maestro-4.1
Component: Maestro | Version:
Severity: minor | Keywords:
External_id: |
When opening a .FeatureSource to an Oracle connection and then hitting the
"Test" button, the Maestro UI updates to show that the resource has
changed and needs a save.
This is even on the same schema where no changes have occurred. This is
confusing and misleading to users as the impression is that there has been
an edit or change that needs to be saved.
Maybe a goo idea for a new Maestro command would be a 'diff' like listing
showing what in the XML (or data) has changed allowing an optional review
before hitting Save.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1925>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
