[mapguide-trac] #1929: Maestro - No Geometry in Layer Prevents Map Save
MapGuide Open Source trac_mapguide at osgeo.org
Sat Jan 21 13:15:28 EST 2012
   Reporter:  crispinatime  |       Owner:  jng
       Type:  defect        |      Status:  new
   Priority:  medium        |   Milestone:  Maestro-4.1
  Component:  Maestro       |     Version:
   Severity:  major         |    Keywords:
External_id:                |
 It is not possible to save a map where there is a layer based on a
 FeatureSource schema/class that has no data populated.
 The BaseMapDefinitionValidator calls GetSpatialExtent, but the aggregate
 query throws at line 1594 of PlatformConnectionBase.cs.
 Whether this is expected or not for a SpatialExtents aggregate is moot as
 it is a valid operation to save a layer that has no data yet (in my
 example a redline SQLite schema).
 This should be handled as a warning, not an error, allowing the layer to
 be saved.
 Workaround is to use an older version of Maestro.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1929>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
