[mapguide-trac] #480: Crash with MgInvalidStreamHeaderException
with GETTILEIMAGE (load test)
trac_mapguide at osgeo.org
Wed Jan 25 09:40:51 EST 2012
#480: Crash with MgInvalidStreamHeaderException with GETTILEIMAGE (load test)
Reporter: zspitzer | Owner:
Type: defect | Status: reopened
Priority: high | Milestone: 2.4
Component: Tile Service | Version: 2.1.0
Severity: major | Resolution:
Keywords: out of memory , #520 | External_id:
Changes (by crispinatime):
* milestone: => 2.4
Comment:
This is still present in MG 2.2 - extract from server logs which hung the
service and w3wp.exe... hope this helps. Will v2.4 based on new MSVC
build help with the error in msvcr90.dll?
Event Type: Warning
Event Source: ASP.NET 2.0.50727.0
Event Category: Web Event
Event ID: 1309
Date: 24/01/2012
Time: 10:56:42
User: N/A
Computer: ______
Description:
Event code: 3005
Event message: An unhandled exception has occurred.
Event time: 24/01/2012 10:56:42
Event time (UTC): 24/01/2012 10:56:42
Event ID: 8880e0790f384f39a9d991ef223b0060
Event sequence: 250
Event occurrence: 1
Event detail code: 0
Application information:
Application domain: /LM/W3SVC/1/Root/____-1-129718669592750903
Trust level: Full
Application Virtual Path: /____
Application Path: E:\Projects\____\
Machine name: HOBRON02WEB
Process information:
Process ID: 6764
Process name: w3wp.exe
Account name: NT AUTHORITY\NETWORK SERVICE
Exception information:
Exception type: Exception
Exception message: Failed to connect, please check network connection
and login information.
Extended error info:
The remote server returned an error: (559)
MgInvalidStreamHeaderException.
Request information:
Request URL: http://____
Request path: /___
User host address: ____
User:
Is authenticated: False
Authentication Type:
Thread account name: NT AUTHORITY\NETWORK SERVICE
Thread information:
Thread ID: 17
Is impersonating: False
Stack trace: at
OSGeo.MapGuide.MaestroAPI.HttpServerConnection.InitConnection(Uri hosturl,
String username, String password, String locale, Boolean
allowUntestedVersion)
at
OSGeo.MapGuide.MaestroAPI.HttpServerConnection..ctor(NameValueCollection
initParams)
Custom event details:
For more information, see Help and Support Center at
http://go.microsoft.com/fwlink/events.asp.
Event Type: Information
Event Source: Application Error
Event Category: (100)
Event ID: 1004
Date: 24/01/2012
Time: 11:34:11
User: N/A
Computer: ____
Description:
Reporting queued error: faulting application w3wp.exe, version
6.0.3790.3959, faulting module msvcr90.dll, version 9.0.30729.5570, fault
address 0x0003bedb.
Data:
0000: 41 70 70 6c 69 63 61 74 Applicat
0008: 69 6f 6e 20 46 61 69 6c ion Fail
0010: 75 72 65 20 20 77 33 77 ure w3w
0018: 70 2e 65 78 65 20 36 2e p.exe 6.
0020: 30 2e 33 37 39 30 2e 33 0.3790.3
0028: 39 35 39 20 69 6e 20 6d 959 in m
0030: 73 76 63 72 39 30 2e 64 svcr90.d
0038: 6c 6c 20 39 2e 30 2e 33 ll 9.0.3
0040: 30 37 32 39 2e 35 35 37 0729.557
0048: 30 20 61 74 20 6f 66 66 0 at off
0050: 73 65 74 20 30 30 30 33 set 0003
0058: 62 65 64 62 bedb
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/480#comment:13>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
