[mapguide-trac] #1935: Error to preview feature of Join/Calculation feature class for SQL Server 2008 provider.
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jan 31 02:06:15 EST 2012
2008 provider.
   Reporter:  christinebao  |       Owner:
       Type:  defect        |      Status:  new
   Priority:  high          |   Milestone:
  Component:  General       |     Version:  2.1.0
   Severity:  major         |    Keywords:
External_id:  1444765       |
 Report from Autodesk QA.
 steps:
 1. New a data connection in studio with SQL Server 2008 provider.
 You can use below server if needed:
 server - cadcmapqa9
 user - sa
 password - isdqa
 data store - San_Fransisco_Ellen
 2.Create a join or calculation based on any feature class.
 3. Preview the data connection.
 4. View feature of the extended feature class generated from join and
 calcuation.
 Result:
 Different exceptions happened.
 Calculation:
 Problem:\nThe application encountered a problem and could not finish the
 operation you just requested properly.\n\nSolution:\nIf it\'s the first
 time you met this problem, try again or restart the application / session;
 otherwise, describe the steps to reproduce this problem to the server
 administrator for suggestions.- MgFeatureServiceHandler.ProcessOperation()
 line 83 file
 d:\build\ims2013\build_40.9\ent\os\server\src\services\feature\FeatureServiceHandler.cpp
 - MgOpSelectFeaturesSpatial.Execute() line 110 file
 d:\build\ims2013\build_40.9\ent\os\server\src\services\feature\OpSelectFeaturesSpatial.cpp
 - MgServerFeatureService.SelectAggregate() line 570 file
 d:\build\ims2013\build_40.9\ent\os\server\src\services\feature\ServerFeatureService.cpp
 - MgServerSelectFeatures.SelectFeatures() line 304 file
 d:\build\ims2013\build_40.9\ent\os\server\src\services\feature\ServerSelectFeatures.cpp
 - MgServerSelectFeatures.SupportsFdoJoin() line 1719 file
 Join -
 An exception occurred in FDO component. Class
 'SHP_Schema:schools_private_ptsExtended' not found -
 MgFeatureServiceHandler.ProcessOperation() line 83 file
 Expectation:
 View feature correctly.
 Regression: not sure
 workaround: n
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1935>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
