[Mapguide-trac] [mapguide-trac] #2017: GETCLASSDEFINITION can return empty content
trac_mapguide at osgeo.org
Fri Jun 1 09:29:44 PDT 2012
Reporter: jng | Owner:
Type: defect | Status: new
Priority: high | Milestone: 2.4
Component: Map Agent | Version:
Severity: critical | Keywords:
External_id: |
Comment(by jng):
Workaround (and for actual comparison) is to use DESCRIBEFEATURESCHEMA
with the CLASSNAMES hint.
Using DESCRIBEFEATURESCHEMA on
Library://Samples/Sheboygan/Data/Parcels.FeatureSource with:
SCHEMA: SHP_Schema
CLASSNAMES: Parcels
Gives the expected class definition XML.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2017#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
