[Mapguide-trac] [mapguide-trac] #2023: Template out LocalNative connection project files
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jun 8 05:44:45 PDT 2012
   Reporter:  jng      |       Owner:  jng
       Type:  task     |      Status:  new
   Priority:  low      |   Milestone:  Maestro-5.0
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
Description changed by jng:
Old description:
> To facilitate the "roll your own LocalNative provider" approach for
> Maestro 5.0, we need to be able to template out the LocalNative project
> and include that in the SDK output.
New description:
 The final setup should be such that all the end-user has to do to roll
 their own LocalNative provider is to sign the MapGuide API binaries using
 the provided signing utility, drop them into a specified directory, and
 run a build script to produce the LocalNative provider assembly
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2023#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
