[Mapguide-trac] [mapguide-trac] #1957: Maestro 4 , ODBC connection: Timeout while saving
trac_mapguide at osgeo.org
Mon Jun 11 04:51:53 PDT 2012
Reporter: janvw | Owner: jng
Type: defect | Status: closed
Priority: low | Milestone: Maestro-5.0
Component: Maestro | Version:
Severity: major | Resolution: fixed
Keywords: | External_id:
Changes (by jng):
* status: new => closed
* resolution: => fixed
Comment:
Fixed with a combination of:
* #2002: Allowing you to build a configuration with a slimmed down
logical schema, by choosing the classes to include in the logical schema.
A full schema walk is not required to present this list of classes to
select from.
* #2004: Eliminating the need to do a full schema walk throughout the
Maestro codebase.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1957#comment:8>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
