[Mapguide-trac] [mapguide-trac] #1834: Measure tool should provide a unit selection option
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jun 14 20:23:29 PDT 2012
   Reporter:  trevorwekel  |       Owner:  trevorwekel
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:  2.4
  Component:  AJAX Viewer  |     Version:  2.2.0
   Severity:  trivial      |    Keywords:  measure, haspatch
External_id:               |
Comment(by yangte):
 Hi Trevor, I have tested your patch on both PHP and JSP, they all worked
 well. when do you plan put this enhancement to the trunk?
 another thing is that when you change the "Measure Units" after some
 points drawn on the map, the total will not be changed. Would you mean to
 do this?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1834#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
