[Mapguide-trac] [mapguide-trac] #1239: On Centos 5.4 x86, Mapguide 2.0.2 Java API crashes Java VM. In debug mode of web throws an exception
trac_mapguide at osgeo.org
Mon Jun 18 01:10:08 PDT 2012
Reporter: rksingh05 | Owner:
Type: defect | Status: new
Priority: high | Milestone: 2.4
Component: General | Version: 2.0.2
Severity: blocker | Keywords: Java Web Crash
External_id: |
Changes (by jng):
* milestone: => 2.4
Old description:
> We built Mapguide 2.0.2 (tar downloaded from web site) on Centos Linux
> 5.5.4 (with some effort - build scripts are available if desired). Non
> java-web portions works fine (except for a font issue) on sheboygan.
> However the java web portion casues the Java VM to crash at site.open().
> Subsequently we create a small Java application to reproduce and get rid
> of possible tomcat related issues. The application crashed alongwith a
> stack trace. We then did debug build of just the web component and the VM
> does not crash but shows certain exceptions happening in MapGuide/JNI
> side.
> Connecting to the same server from a windows TomCat works fine (except
> for the aforementioned font issue)
> The calls never reach the MgServer. Note that the attached webconfig.ini
> has 192.168.1.95 as the address for the site server.
> Following files are being attached:
> TestMg.java - a simple application that does site.open (Please set the
> path of webconfi.ini to your requirement). Crash/Exception happens at
> site.open
> webconfig.ini - the ini file being used
> vmcrashreport.err.txt - the error file generated when VM crashed in non-
> debug build mode
> console.op.txt - the output of console showing the issue. the same is
> also being copy-pasted here
> Script started on Sun 10 Jan 2010 07:44:06 PM IST
> javac -classpath .:/usr/local/mapguideopensource/webse
> erverextensions/www/WEB-INF/lib/MapGuideApi.jar TestgM.java
> java -classpath .:/usr/local/mapguideopensource/webser
> -Djava.library.path=/usr/local/map
> pguideopensource/webserverextensions/lib TestMg
> configPath:/usr/local/mapguideopensource/webserverextensions/www/webconfig.ini
> InitDone
> userInfo Doneorg.osgeo.mapguide.MgUserInformation at de6ced
> Site doneorg.osgeo.mapguide.MgSite at 1fb8ee3
> (3076852624) MgSiteManager::Initialize()
> Exception
> - MgSite.Open line 105 file Services/Site.cpp
> - MgSite.Authenticate line 1336 file Services/Site.cpp
> - MgServerConnection.Open line 106 file Services/ServerConnection.cpp
> (3085924032) MgSiteManager::~MgSiteManager()
> ]0;root at localhost:~/test_jni[root at localhost test_jni]# exit
> exit
> Script done on Sun 10 Jan 2010 07:44:50 PM IST
New description:
side.
Connecting to the same server from a windows TomCat works fine (except for
site.open
debug build mode
console.op.txt - the output of console showing the issue. the same is also
InitDone
Exception
exit
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1239#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
