[Mapguide-trac] [mapguide-trac] #2029: Developer Guide samples should set up the required WebLayout
trac_mapguide at osgeo.org
Mon Jun 18 02:04:54 PDT 2012
Reporter: jng | Owner: jng
Type: defect | Status: new
Priority: low | Milestone: 2.4
Component: Samples | Version: 2.4.0
Severity: trivial | Keywords:
External_id: |
The current Developer Guide samples require manually loading their
associated packages first in order to function.
But if you look at what is actually inside these packages, it is just a
WebLayout document, which we can easily load in ourselves through code.
Doing it this way, we can do away with needing to load packages and it
also demonstrates loading dynamic WebLayout documents.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2029>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
