[Mapguide-trac] [mapguide-trac] #2031: Update Sheboygan Dataset
trac_mapguide at osgeo.org
Tue Jun 19 07:47:30 PDT 2012
Reporter: jng | Owner:
Type: task | Status: new
Priority: low | Milestone: 2.4
Component: Samples | Version:
Severity: trivial | Keywords:
External_id: |
As Sheboygan is our reference data set for testing all aspects of MapGuide
and viewer functionality, it should fully encompass all the possible
scenarios that we would want to demonstrate and/or test.
Update the Sheboygan Data set with the following:
Symbol Definitions:
* Trees (Image-based? Geometry-based?)
Watermarks:
* A text-based watermark
* An image-based watermark
Layers:
* Trees (pointing to the previously un-used Trees.FeatureSource, using
the Trees Symbol Definition)
Maps:
* Maps/Sheboygan.MapDefinition to include the Trees layer
* MapsTiled/Sheboygan.MapDefinition to include the Trees layer
* A Sheboygan.MapDefinition containing a mixture of tiled and untiled
layers
* Variants of the above 3 re-projected to WGS84.PseudoMercator
Flexible Layouts:
* Refreshed copies of the original 5 layouts (to include the latest set
of widgets)
* Variant of the above 5 referencing the tiled Sheboygan MapDefinition
* Variant of the above 5 referencing the mixed Sheboygan Map Definition
* Commercial-based variants of the above 15 permutations (with OSM
support activated, as this does not require API keys)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2031>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
