[Mapguide-trac] [mapguide-trac] #2033: FeatureClass dropdown displays wrong
trac_mapguide at osgeo.org
Thu Jun 21 05:09:27 PDT 2012
Reporter: hm | Owner:
Type: defect | Status: new
Priority: low | Milestone: Maestro-5.0
Component: General | Version:
Severity: trivial | Keywords:
External_id: |
If I change the FeatureClass of a layer in Maestro 5.02b and save it the
dropdown is reset to the first feature class in the list. If I open the
layer with Maestro4 the layer is set correct. It seems that when the form
is loaded or refreshed that the FeatureClass dropdown is just not set
correctly. The problem is that if you open the layer to change some other
property and save, then the feature class is reset to the first in the
list. This is not very desirable.
I only tried this with layers pointing to King Oracle feature sources, so
I am not sure if the bug affects all kinds of feature sources or just
Oralce.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2033>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
