[Mapguide-trac] [mapguide-trac] #2041: Error in GetCommonParent
trac_mapguide at osgeo.org
Mon Jun 25 05:29:00 PDT 2012
Reporter: hm | Owner:
Type: defect | Status: new
Priority: low | Milestone: Maestro-4.0-maintenance
Component: General | Version:
Severity: trivial | Keywords:
External_id: |
In the file Maestro.Base\UI\SiteExplorer.cs in the method GetCommonParent
there is an error:
internal static string GetCommonParent(RepositoryItem[] data)
if (data.Length > 0)
if (data.Length == 1)
if (data[0].IsFolder)
return data[0].ToString();
The ToString will return the name of the object type
"Maestro.Base.UI.RepositoryItem" and not the ResourceId "Library://../.."
should be:
return data[0].ResourceId;
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2041>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
