[Mapguide-trac] [mapguide-trac] #2039: Maestro - Schema Versions and Updates
trac_mapguide at osgeo.org
Mon Jun 25 09:06:00 PDT 2012
Reporter: crispinatime | Owner: jng
Type: defect | Status: new
Priority: low | Milestone: Maestro-5.0
Component: Maestro | Version:
Severity: minor | Keywords:
External_id: |
Comment(by crispinatime):
It's only an unsaved one that fails.
It's more due to the fact that a new/blank v2.3 watermark will not
*immediately* save without error (can you replicate that?).
You need to change the type to "image" and upload an image or work out
which are the mandatory elements required for "text" ... so it's actually
more about default usability than upgradeability.
Having found both a "WatermarkDefinition-2.3.0.xsd" and a
"WatermarkDefinition-2.4.0.xsd" under
\Maestro\OSGeo.MapGuide.MaestroAPI\Schemas both appear identical apart
from that the 2.3 has:
<xs:include schemaLocation="SymbolDefinition-1.1.0.xsd"/>
and the 2.4 has:
<xs:include schemaLocation="SymbolDefinition-2.4.0.xsd"/>
But only the 2.3 is copied to the \out\[BUILD]\Schemas folder?
So I still don't see the difference or need but I may be missing
something!
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2039#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
