[Mapguide-trac] [mapguide-trac] #2049: mgp loading error: Not enough space
trac_mapguide at osgeo.org
Wed Jun 27 05:47:00 PDT 2012
Reporter: znarf1965 | Owner:
Type: defect | Status: new
Priority: high | Milestone:
Component: Map Admin | Version: 2.4.0
Severity: critical | Keywords: Mapguide Administrator mgp
External_id: |
On loading some mgp by use of Administrator I get the following error:
An exception occurred in DB XML component. Error: Not enough space
This happens only to some of the mgp, not all. I'm using mapguide 2.4
beta.
This does not happen to Autodesk Infrastructure Server 2013.
This is a critical error because backups are not safe and it is also very
difficult to deploy some projects.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2049>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
