[mapguide-trac] #1960: ByteSource and ByteReader memory leak in Java Api
MapGuide Open Source trac_mapguide at osgeo.org
Fri Mar 2 01:13:34 EST 2012
   Reporter:  hubu      |       Owner:  Andy Zhang
       Type:  defect    |      Status:  new
   Priority:  high      |   Milestone:  2.3
  Component:  Web API   |     Version:  2.2.0
   Severity:  critical  |    Keywords:  Memory leak
External_id:  1453408   |
 Memory leak happens when get MgByteReader from a MgByteSource. This only
 happens in Java Api. It's a Swig issue.
 Here is the sample code:
             for (int i = 0; i < maxCount; i++)
                                     MgByteSource byteSource = new
 MgByteSource(xmlBytes, xmlBytes.length);
                                 MgByteReader
 layerDefinitionNewResourceContent = byteSource.GetReader();
                 layerDefinitionNewResourceContent.delete();
                 layerDefinitionNewResourceContent = null;
                     byteSource.delete();
                     byteSource = null;
                     System.gc();
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1960>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
