[mapguide-trac] #1967: Dropping layer into group doesn't work
trac_mapguide at osgeo.org
Wed May 9 08:53:39 EDT 2012
Reporter: andrewd | Owner: jng
Type: defect | Status: closed
Priority: low | Milestone: Maestro-5.0
Component: Maestro | Version: 2.1.0
Severity: minor | Resolution: worksforme
Keywords: | External_id:
Comment(by andrewd):
You've just described the bug (or at least, perceived bug) right
there...Generally, you don't have to preselect a folder when dragging and
dropping in other software.
As a user, I certainly assume that things will just go where I drop them,
whether or not I preselect a folder. The fact that they don't may be by
design, but it's very much non-standard, and I'd consider changing it if
you'd like to make Maestro more user-friendly.
Change it to an enhancement request if you'd rather not treat it as a
bug...but I'd keep it on the list.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1967#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
