[mapguide-trac] #1967: Dropping layer into group doesn't work
MapGuide Open Source trac_mapguide at osgeo.org
Wed May 9 09:19:32 EDT 2012
 Reporter:  andrewd  |         Owner:  jng
     Type:  defect   |        Status:  closed
 Priority:  low      |     Milestone:  Maestro-5.0
Component:  Maestro  |       Version:  2.1.0
 Severity:  minor    |    Resolution:  worksforme
 Keywords:           |   External_id:
Comment(by andrewd):
 Ok - got more detail for you...
 Expand the group folder (put some layers into it first). Drag something
 into it without putting your mouse over the folder, so it gives you the
 short horizontal line indicating it's going to put it in that folder (this
 happens when hovering between 2 layers in the group)...drop the layer, and
 it will be placed at the root, not the folder. This is more of a problem
 with large expanded groups, when you can't see the group folder icon.
 Basically, the short lines (the ones that appear in folders) never seem to
 work.
 Also, if you happen to drop a layer on top of an existing layer in a
 group, maybe you could make that be treated as though it was dropped in
 the group - right now, if you do that, it gets put in the root.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1967#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
