[mapguide-trac] #2003: Layer Preview fails if extents and
coordinate system cannot be inferred from Feature Source
trac_mapguide at osgeo.org
Mon May 14 23:28:58 EDT 2012
#2003: Layer Preview fails if extents and coordinate system cannot be inferred
from Feature Source
Reporter: jng | Owner: jng
Type: defect | Status: new
Priority: low | Milestone: Maestro-4.0-maintenance
Component: Maestro | Version:
Severity: trivial | Keywords:
External_id: |
If you a layer preview which is configured against a Feature Source
without a coordinate system, the preview will fail because the generated
Map Definition XML is not valid (due to missing <CoordinateSystem> and
<Extent> elements)
Maestro needs to gracefully handle such scenarios.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2003>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
