[Mapguide-trac] [mapguide-trac] #2166: Simplify execution of web tier test suite
trac_mapguide at osgeo.org
Thu Nov 1 06:52:33 PDT 2012
Reporter: jng | Owner: jng
Type: enhancement | Status: new
Priority: low | Milestone: 2.5
Component: Web API | Version:
Severity: trivial | Keywords:
External_id: |
The PHP-driven web tier test suite can be improved in the following
fashion:
* Add a batch file that can prepare the required environment for running
the test suite from the command line
* The PHP test suite should have an option to exclude the mapagent tests
(as this requires a setup of a web server, which may be difficult to set
up in an automated fashion)
* XML content assertions should not be sensitive to whitespace. These
tests only care that the XML content matches.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2166>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
