[Mapguide-trac] [mapguide-trac] #2168: Cannot duplicate definitions in MAPCSLIBRARY
trac_mapguide at osgeo.org
Mon Nov 5 00:50:11 PST 2012
Reporter: ChristineBao | Owner: Christine.bao@…
Type: defect | Status: new
Priority: medium | Milestone:
Component: General | Version: 2.1.0
Severity: trivial | Keywords:
External_id: 1478276 |
Report from Autodesk:
+++ This defect cannot be verified in the DEV environment +++
Unless, the following tweaks are applied
- install the dictionary files; I can provide an installer
alternatively, you can install a recent M3D which will install the
dictionaries into C:\ProgramData\Autodesk\Geospatial Coordinate Systems
2014
- unset the MENTOR_DICTIONARY_PATH variable in the blue command prompt (!)
1) Start M3D
2) Run MAPCSLIBRARY
3) search for DHDN/BeTA_to_ETRF89
4) Click 'Duplicate'
Result:
Error message appears.
Expected:
The definition can be duplicated.
Remarks:
The code does a check in
\\MgDev\Common\Gis\UI\CoordinateSystem\Controls\CoordinateSystemLibrary.xaml.cs::DuplicateExecuted()
private bool CheckWriteAcess()
bool hasWriteAccess =
CSDefinitionLibrary.Instance.AreDictionaryFileWriteable();
if (!hasWriteAccess)
System.Windows.MessageBox.Show(String.Format(Properties.Resources.NoWriteAceess,
CSDefinitionLibrary.Instance.GetDicitonaryDir()),
String.Empty, MessageBoxButton.OK,
MessageBoxImage.Error);
return hasWriteAccess;
This typically return [false].
The fix should be made in the GIS platform.
There, if a 'User mentor dictionary path' is defined, the code should
check the actual target - not the CSD file in
[C:\ProgramData\Autodesk\Geospatial Coordinate Systems 2014].
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2168>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
