[Mapguide-trac] [mapguide-trac] #2174: GDAL - MapImage with stripes
trac_mapguide at osgeo.org
Thu Nov 15 18:52:22 PST 2012
Reporter: zspitzer | Owner:
Type: defect | Status: new
Priority: high | Milestone:
Component: Rendering Service | Version: 2.4.0
Severity: major | Keywords:
External_id: |
I'm trying to produce large high quality plots with the GetMapImage-
methode.
When using the GDAL Raster Provider I get stripes on my image. Source
files
are either 8 bit or 24 bit. It doesn't matter if it is a raster
FeatureSource of type 'single' or 'composite'. I've tested with different
raster output formats (PNG/PNG8/JPG) but get always the same result like
in
this image:
You can test it with the TrueMarble
http://129.123.16.127/globe/TrueMarble_GeoTIFF/TrueMarble.8km.5400x2700.tif.gz
dataset.
Then create FeatureSource, LayerDefinition and MapDefinition and call the
GetMapImage method on MapAgent Test Pages pointing to your MapDefinition.
And you can see ...
http://osgeo-org.1560.n6.nabble.com/file/n5016550/italy.png
With the following settings I get the above image:
Format: PNG
View Center X: 0
View Center Y: 0
ViewScale: 10000000
Display Dpi: 75
Display width: 4000
Display height: 4000
(don't forget to adjust the raster settings in serverconfig.ini to allow
such high resolution output for GDAL Provider)
Discussion: http://osgeo-org.1560.n6.nabble.com/GDAL-MapImage-with-
stripes-td5016254.html#a5016599
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2174>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
