[Mapguide-trac] [mapguide-trac] #2176: Can't delete connection
trac_mapguide at osgeo.org
Fri Nov 16 03:47:52 PST 2012
Reporter: osjonathan | Owner: jng
Type: defect | Status: new
Priority: low | Milestone: Maestro-5.0
Component: Maestro | Version:
Severity: major | Keywords:
External_id: |
I have a connection on site explore. It keeps bugging out with "session
lost". So I click the layer and then the little red X. It asks me to
delete it and I say "yes". This then gives me the below error.
Object reference not set to an instance of an object.
System.NullReferenceException: Object reference not set to an instance of
an object.
at Maestro.Base.UI.SiteExplorer.get_ConnectionName() in c:\Program
Files (x86)\Jenkins\jobs\Maestro
trunk\workspace\Maestro.Base\UI\SiteExplorer.cs:line 113
at Maestro.Base.UI.SiteExplorer.trvResources_SelectionChanged(Object
sender, EventArgs e) in c:\Program Files (x86)\Jenkins\jobs\Maestro
trunk\workspace\Maestro.Base\UI\SiteExplorer.cs:line 88
at Aga.Controls.Tree.TreeViewAdv.OnSelectionChanged() in c:\Program
trunk\workspace\Thirdparty\TreeViewAdv\Aga.Controls\Tree\TreeViewAdv.cs:line
105
at Aga.Controls.Tree.TreeViewAdv.EndUpdate() in c:\Program Files
355
at Aga.Controls.Tree.TreeViewAdv.set_SelectedNode(TreeNodeAdv value) in
trunk\workspace\Thirdparty\TreeViewAdv\Aga.Controls\Tree\TreeViewAdv.Properties.cs:line
689
at Maestro.Base.UI.SiteExplorer.RefreshModel(String connectionName,
String resId) in c:\Program Files (x86)\Jenkins\jobs\Maestro
trunk\workspace\Maestro.Base\UI\SiteExplorer.cs:line 193
at Maestro.Base.Commands.SiteExplorer.DeleteSelectedItemsCommand.Run()
trunk\workspace\Maestro.Base\Commands\SiteExplorer\DeleteSelectedItemsCommand.cs:line
85
at ICSharpCode.Core.WinForms.ToolBarCommand.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e,
ToolStripItemEventType met)
at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e,
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons
button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message&
m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg,
IntPtr wparam, IntPtr lparam)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2176>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
