[Mapguide-trac] [mapguide-trac] #2186: Invalid stream header exception
MapGuide Open Source trac_mapguide at osgeo.org
Wed Nov 21 04:13:51 PST 2012
   Reporter:  cmy      |       Owner:
       Type:  defect   |      Status:  new
   Priority:  high     |   Milestone:
  Component:  General  |     Version:  2.0.2
   Severity:  trivial  |    Keywords:
External_id:           |
 ####<2012-11-15 上午09时43分30秒 CST> <Error> <HTTP> <jjgl> <qxx> <[ACTIVE]
 ExecuteThread: '20' for queue: 'weblogic.kernel.Default (self-tuning)'>
 <<WLS Kernel>> <> <> <1352943810996> <BEA-101017>
 <[weblogic.servlet.internal.WebAppServletContext at 182d86 - appName:
 'mapguide', name: 'mapguide', context-path: '/mapguide'] Root cause of
 ServletException.
 org.osgeo.mapguide.MgInvalidStreamHeaderException: Invalid stream header
 exception.
         at
 org.osgeo.mapguide.MapGuideJavaApiJNI.MgMap_Create__SWIG_0(Native Method)
         at org.osgeo.mapguide.MgMap.Create(MgMap.java:46)
         at
 jsp_servlet._mapviewerjava.__mapframe._jspService(__mapframe.java:329)
         at weblogic.servlet.jsp.JspBase.service(JspBase.java:34)
         at
 weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper.java:227)
         at
 weblogic.servlet.internal.StubSecurityHelper.invokeServlet(StubSecurityHelper.java:125)
         at
 weblogic.servlet.internal.ServletStubImpl.execute(ServletStubImpl.java:283)
         at
 weblogic.servlet.internal.ServletStubImpl.execute(ServletStubImpl.java:175)
         at
 weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.run(WebAppServletContext.java:3272)
         at
 weblogic.security.acl.internal.AuthenticatedSubject.doAs(AuthenticatedSubject.java:321)
         at
 weblogic.security.service.SecurityManager.runAs(SecurityManager.java:121)
         at
 weblogic.servlet.internal.WebAppServletContext.securedExecute(WebAppServletContext.java:2019)
         at
 weblogic.servlet.internal.WebAppServletContext.execute(WebAppServletContext.java:1925)
         at
 weblogic.servlet.internal.ServletRequestImpl.run(ServletRequestImpl.java:1394)
         at weblogic.work.ExecuteThread.execute(ExecuteThread.java:209)
         at weblogic.work.ExecuteThread.run(ExecuteThread.java:181)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2186>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
