[Mapguide-trac] [mapguide-trac] #2192: MgMultiGeometry::Deserialize doesn't work with MgAgfStream
trac_mapguide at osgeo.org
Fri Nov 30 11:34:10 PST 2012
Reporter: waltweltonlair | Owner: waltweltonlair
Type: defect | Status: assigned
Priority: high | Milestone: 2.5
Component: General | Version: 2.4.0
Severity: major | Keywords:
External_id: 1460281.01 |
Changes (by waltweltonlair):
* status: new => assigned
* external_id: => 1460281.01
Comment:
This is a regression introduced with changeset r3502 to fix ticket #788.
In that submission special code was added to get the geometry type via a
peek operation. The peek operation was coded to work with !MgStream, but
it doesn't work with !MgAgfStream.
!MgStream inherits from !MgStreamReader / !MgStreamWriter, and the default
implementations of the Get / Write methods in !MgStreamReader /
!MgStreamWriter serialize stream header / version / data header fields.
The peek operation added in r3502 was coded to handle this.
!MgAgfStream inherits from !MgStream and overrides the Get / Write
methods. It does not serialize stream header / version / data header
fields.
To fix this we simply need to enhance the code in
MgMultiGeometry::Deserialize to check the type of the passed-in !MgStream.
If it's an !MgAgfStream then we need to use the original pre-3502 code for
doing the peek operation. If it's a pure !MgStream then we use the code
added in r3502.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2192#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
