[Mapguide-trac] [mapguide-trac] #2137: WMS Feature Source editor fixes and loose ends
trac_mapguide at osgeo.org
Fri Oct 5 01:03:29 PDT 2012
Reporter: jng | Owner: jng
Type: defect | Status: reopened
Priority: low | Milestone: Maestro-4.0-maintenance
Component: Maestro | Version:
Severity: trivial | Resolution:
Keywords: | External_id:
Changes (by jng):
* status: closed => reopened
* resolution: fixed =>
Old description:
> * The WMS_Schema: prefix should not be prepended to the actual WMS layer
> names
> * Fix anchoring issues so the WMS Configuration UI can be resizable
New description:
* ~~The WMS_Schema: prefix should not be prepended to the actual WMS layer
names~~
* ~~Fix anchoring issues so the WMS Configuration UI can be resizable~~
* Use the GetSchemaMapping API to construct a default configuration
document instead of "rolling our own", as it may contain other useful
information from the originating WMS server that would get lost if we
built our own one from scratch.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2137#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
