[Mapguide-trac] [mapguide-trac] #2134: Cannot delete resource with different schema version
MapGuide Open Source trac_mapguide at osgeo.org
Sun Oct 7 21:55:28 PDT 2012
   Reporter:  gBecker  |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-5.0
  Component:  Maestro  |     Version:  2.4.0
   Severity:  minor    |    Keywords:
External_id:           |
Comment(by jng):
 Was this repo a straight drop/replace of the Repositories folder into the
 new MG install?
 eg. 2.0.2 repo -> drop into 2.2 install -> drop into 2.4 install
 I'm thinking the 2.4 repo is somehow "tainted" by 2.0.2 data structures
 through this approach.
 I would only consider this to be a serious bug if this issue is
 reproducible on a repository that was upgraded in this fashion:
 (http://wikihelp.autodesk.com/Infr._Map_Server/enu/2013/Help/0008-Installa0/0008-Installa8/0009-Upgrade_9)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2134#comment:6>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
